CluTcH BelL PrOBleM!
I just got my ofna .26 force in my revo and almost through breakin the the bells teeth about 5 come off. could it be that i have a metal spur gear causing the problem and what can i do to fix it.
LA
RE: CluTcH BelL PrOBleM!
well if you have a steel spur gear you cant use the stock clutchbell you have to use a hardened clutchell.
http://www.robinsonracing.com/catalo...xas.html#bells
