Good batteries for an EMAXX
Whats a good battery at tower hobbies for an EmAXx? I want the best bang for the buck. So that means as cheap as possible, but still good.
And should I be looking at Nicad or NiMH.?
My Feedback: (325)
RE: Good batteries for an EMAXX
Look at 3300 gp minimum mah. The best deal on them is radio shack $25. The problem using a cheap battery in the e-maxx is that it will ruin it prety quickly. The maxamps tq 4400 or any IB or gp cells should be good too.
PA
hello i would get vemon batterys 3300mah or more then get a real good peak charger and you should be set and change out the stock battery connectors for a deans ultra plugs hahahah any one ever have the stock contectors weld together from suking crazy amps[sm=spinnyeyes.gif][sm=spinnyeyes.gif][sm=spinnyeyes.gif][sm=spinnyeyes.gif]
GA
Just have these folks custom make you a couple packs. They may cost a bit more initially but will last longer and give you better results. Believe me, good batteries are well worth the expense.
http://www.cheapbatterypacks.com/mai...rer=4&model=21
FL
Look for batteries that comes in pairs they are usally cheaper.
http://www2.towerhobbies.com/cgi-bin...&I=LXCUH3&P=ML
http://www2.towerhobbies.com/cgi-bin...&I=LXCLS6&P=ML
http://www2.towerhobbies.com/cgi-bin...&I=LXHBP3&P=ML
http://www2.towerhobbies.com/cgi-bin...?&I=LXCTV8&P=7
