Radical 621p motor
IL
RE: Radical 621p motor
Its a highly advanced Italian Engine. Really nice. I just cant find a dam way to start other then starter box.
http://www.internet-rc.com/rarc62ofco21.html
40,000 RPM
40,000 RPM
Probably should have done your home work before you spent your money. Then you'd know up front what you'll need.
ORIGINAL: rawkfist2
40,000 RPM
40,000 RPM
FL
A Sullivan Tiger Drive may be your answer. They basically come in two sizes: 6mm and 8mm, just measure your starter shaft, or take the mill to your LHS to get the right one.
PA
Looks like a nice mill. Try a tiger drive or you could buy a starter box on ebay for cheap, some have said they seen a starter box go for $20 or so dollars. But try those.
I would just get a starter box if you spent that much on the motor why ruin it by screwing the back plate up it was designed to be bump started
CO
The add says ask any racer, and they will tell you its the fastest.
I've asked several racers and they have never heard of it.
Rawkie just buy a picco
