Newbie Help Please
Newbie Help Please
Ok my newbie question How can I tell witch is the right way to go in my son messed with them and now I'm screwed on the fron witch side are the screws spouse to be facing and the same with the rear and is there a difference from the front and rear
FL
RE: Newbie Help Please
I thinkl you're referring to the differential here. Look at the back of the truck, from where the bumper should be. The screw heads should be on the right hand side of the diff housing. Now turn the truck around so you are looking at the front of the truck, just like you were looking at the back. The screw heads should be on the right, just like the back. Now look at the truck from the top. The diff housing screws should be opposite each other.
