Revo 2.5 to 3.3 parts needed???
Hi, I bougth a revo 2.5 used off ebay, and I want to upgrade it to 3.3 specs for racing, I am planning to buy the 3.3 chassis but I dont know what I have to get to do the swap, I mean do I need longer center driveshafths?
Also I plan to get the the FOC but I also want to get the center diff, I can still use the center diff with the FOC Kit? and also do I need the longer chassis to run the Center diff?
Last question, is really that important having the new extended chassis? thanks in advance
WA
RE: Revo 2.5 to 3.3 parts needed???
you need the steering links, no you do not need longer center UV drives. and the center diff is a FOC, you can't have reverse and have a center diff, but you don't need the FOC kit to use the center diff. and no, you don't have to have a 3.3 chassis to run a CD, it is all inside the trannsmission, though you will have to cut ourt material on the 2.5 chassis to use the rear brake. as for importance, I have no idea, I don't race, I just bought a 2.5 chassis, the rollcages are cheaper, I can get the lunsford links, and when I get the vantage chassis the rollcage will fit (the vantage extended chassis is extended behind the motor).
NC
Here is a link to everything you need. You can buy it as a package even comes with a body of your choice.
[link=http://www.teknorc.com/product_info.php?cPath=67&products_id=490]http://www.teknorc.com/product_info.php?cPath=67&products_id=490[/link]
Here is exactly what you need to convert a 2.5r to a 3.3
http://www.teknorc.com/product_info....roducts_id=490
Beasly, lol, you beat me to it
NC
ORIGINAL: Outkazt
