big block kit
VA
RE: big block kit
also will that motor run on the stock exhaust.
I know it will limit its output but will it run without being choked up to the point of choking out.
also will it clear the stock rear a arm with rotostart.
RE: big block kit
the traxxas mount will work but that exhaust will choke the life outta that motor your gonna have to go side pipe to get the most outtaany big block application!
RE: big block kit
The stock pipe REALLY kills the performance on big blocks. You can probably get it to work by doing what my bro and others have done We put a hpi 4.6 in his revo with a roto start by moving tranny forward on chassis about 3/8-5/16 inches by removing 4 tranny bolts, pulling out tranny, then redrilling chassis holes I THINK 5/16 inch more toward front, then using the offset arms. I picked up a ofna jp2 pipe and header for it after trying stock pipe, and a trinity high flow pipe(totally garbage) and it screams. Hope this helps.
RE: big block kit
Or just go with the new era mount. Modding the chassies isn't needed with this mount. The only pipe that works best with the sts .30 is the sts inline pipe. There have been countless of people who have tried other pipes but for some reason the sts pipe gave it the best power. If you go into the hpi forums, there is a seperate forum just for sts engines. You might wanna check that out first.
VA
RE: big block kit
Thats an expensive pipe,but i heard it works wonders.
I was thinking along the lines of a $20 mgt pipe but im going on a trip and i will be breaking it in but i dont think i will have the pipe in time.
I will probably move the tranny forward and see if that works if that doesnt work I will just have to use my os .18 for the trip but i guess that will be alrigt.
RE: big block kit
ORIGINAL: dirt101
RE: big block kit
ORIGINAL: dirt101
Is it that funny? I mean seriously
Honestly, save the money and get a JP-3 or a STS pipe.
RE: big block kit
ORIGINAL: BAMF90
You don't want to run anything other then an STS pipe on an STS engine. They are made specifically for them.
CA
RE: big block kit
Well, I have a Revo 2.5 with a STS .30 in it using a Qoncepts kit. I at first used the MGT pipe and it worked just fine. I recently switched to a side pipe using the recommended STS pipe from STS for the .30. I like the looks and it is cool having the exhaust come out the side, and it looks real racey. The MGT pipe worked just as well, but a little lowder. For 20.oo and ease of installation you can not do better than the MGT pipe. The STS .30 is a fine engine in the Revo, especially with the roto-start and RPM A-arms it can be used with a Qoncepts kit, but I have never found the STS .30 as great as some people say. I have two of them and one is modified by a very popular person with the STS's. So, go ahead and use the MGT pipe, it is WAY, WAY, WAY better with the STS than the stock revo pipe.
Hope this helps.
Dennis
RE: big block kit
^^^How many gallons do you have threw the motor so far. For this motor it takes a full gallon to break in. Then you need to take out the shims and set those up right... Not untill you do all of this will the motor really show it power. I think anything bigger then a .26 in a revo 2.5 will be awsome power.
CA
RE: big block kit
The STS .30 in the Revo I have has well over three gallons through it. Two gallons were used for break-in care. It has lots of compression and no "pinch" left. It is at it's peak on 20% O'Donnells. Only uses one of the thick copper shimms.
Dennis
Dennis
CA
RE: big block kit
what gearing are you running i was thinking 18-20 cluthchbell and a 36 spur.
Dennis
VA
RE: big block kit
I might see if I can stretch and get the quoncepts mount. I have heard nothing but good things about it. now I came up with a new problem
lets add things up here
sts .30 dm $140 $140
qoncepts stage 3 bb kit $85 $225
Tekno or Rpm rear a-arms $10-20 $245
RR clutchbell $20 $265
Mgt pipe $20 $285
Clutch shoes and springs $?? $285+
A high school kid with too much time on his hands $ priceless
Im not shure how much the clutch shoes and springs will cost but it shouldn't be to much.
Mgt pipe $20 $285
CA
RE: big block kit
Clutch shoes and springs will kill $20.00. You also forgot the forward only gear changes in the transmission.
Also, look forward to a lot of tinkering to get the throttle linkage working right and probably a more powerful throttle servo. Last, the Qoncepts kit locks you into the STS engine with roto-start. Only one that fits. Any other engine using bump start and you need a bump start starter box. Only way around this is to not use the Qoncepts, but rather the new era BB kit. Also, don't forget the Traxxas engine-chassis brace which is a must and the Qoncepts chassis brace. I use both to hold the torque of the engine and movement of gear mesh caused by flexing.
In all respects, this mod is both expensive and a lot of work. For the same money, you could buy the Picco .26 engine with Ofna motor mounts that is a drop in.
I would recommend doing the BB installation in the REVO as long as you have pleanty of time and willingness to do the pretty complicated installation, and pleanty of money to throw at it. Last the STS .30 sucks the fuel tank empty really fast.
Dennis
Dennis
VA
RE: big block kit
Is the STS .30 shorter than most big blocks? If its not why would it be the only one to fit, becuase I kinda bidded on a picco .28 p3 with a v6 clutch. I am the high bidder at $90 so if any one wants to come outbid me you are welcome. It comes with roto back plate a bump start backplate. Its got like 1.25 gallons on it. If I win I will do the traxxas mount with the tranny scooted forward idea.
VA
RE: big block kit
I think 12 hrs.
I might keep bidding anyways its just so convincing. I have yet to read ONE bad report on the picco p3 and I have been reading for hours and hours. The STS has like a 95% good report so its convincing too. But come on a v6 clutch too I just couldnt pass it up.
RE: big block kit
Yea this is true... The only thing is that the last 2 hours is when it really starts to shoot up. [] What you think would be a great deal just got another $60 addaed on by 3 hours left. Best way to keep the price low is not to bid until the end. Otherwise you will just keep trying to out bid someone else for the 12 hours until its not a good deal anymore.. then its [:'(]
