Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
sleeve piston problem
Old 07-02-2007, 01:02 PM
Default sleeve piston problem
i think my owb is bad cuz i can turn the engine over in both directions so i was going to rebuild the engine. ive been following the way on the traxxas website and i cannot get the sleeve out.i heated the crankcase to 130 f and tried to push it up with a plastic stick thing and it still wont budge help!
Old 07-02-2007, 01:18 PM
Default RE: sleeve piston problem
sumone help
Old 07-02-2007, 01:27 PM
jarett 92's Avatar
by plastic stick thing do u mean a zip tie?
no like a lego piece
Old 07-02-2007, 01:30 PM
jarett 92's Avatar
use a zip tie...put it into the exhaust post and turn the flywheel so the piston moves up...and the sleeve should slide right out.
Old 07-02-2007, 01:33 PM
adam032981's Avatar
ORIGINAL: jarett 92
Thats what I would do to
Old 07-02-2007, 01:34 PM
should i heat the crank case?
Old 07-02-2007, 01:36 PM
jarett 92's Avatar
i didnt...make came right out.
Old 07-02-2007, 01:49 PM
is that right?
ID:	715149   Click image for larger version
Old 07-02-2007, 01:54 PM
that looks ok if it still dosent work its because the zip tie is too bug try using a small one and you dont hace to zip it lol
jarett 92's Avatar
yep...now u just move the piston up with the flywheel and the sleeve should come out far enough u can grab it.
Old 07-02-2007, 01:55 PM
wow it didnt work. lol should i use a smaller one?
Old 07-02-2007, 01:56 PM
jarett 92's Avatar
what didnt work about it?
Old 07-02-2007, 01:58 PM
it doesnt move the sleeve it just jams and stays there
Old 07-02-2007, 01:59 PM
jarett 92's Avatar
push harder...if that doesnt work try heating it up.
Old 07-02-2007, 02:03 PM
Danju's Avatar
use some muscle man...your not gonna break anything.
Old 07-02-2007, 02:13 PM
thank u jarret but u coulda told me i had to use a vice lol
Old 07-02-2007, 02:26 PM
i found the problem why it wouldnt start
the piston has a huge chip in it.
should i buy a new piston plus sleeve or just get a new engine
Old 07-02-2007, 02:33 PM
Beasley1's Avatar
If you still have the 2.5 and have the $$$ I would upgrade to something else. Give it some more power.
Im a picco guy myself.
Old 07-02-2007, 02:38 PM
im lookin to spend 100-180 on a descent engine a .18
Old 07-02-2007, 04:05 PM
ORIGINAL: 1Nightrider1
[link=http://www2.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=os+.18tm&FVPROFIL=++&search3=Go]os .18tm at towerhobbies[/link]
Old 07-02-2007, 10:13 PM
jarett 92's Avatar
or u can go a little higher at 190 and getting the Picco .26 maxx...lots more power than the 18tm
Old 07-02-2007, 10:25 PM
adam032981's Avatar
ORIGINAL: jarett 92
Ya but some Pico's have air leaks
Old 07-02-2007, 11:15 PM
im gonna go with the drop in os 18 tm
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
