picco temps
picco temps
what tempreture should mypicco .26 max run at when tuned for great speed and what is the hottest i shold let it get thanks joel please reply asap
RE: picco temps
just tune it for performance not temp though. although the hotter you run it the shorter the life span. the picco .15 in my 4-tec doesnt ever exceed 212 on a hot day and it will tear the streets up all day long. with the ofna .21 on my maxx its usually about 240-245 and it will tear the yard up all day. i suppose i could lean it out a bit to get (everything) out of the engine but there is so much these little nitro engines can do.
RE: picco temps
Mine runs about 250 consistant but Ofna said it can run up about 280-300. I had problems when I first got mine. It would not get below 280 and times it would get 310. It had a leak which they fixed under warranty but they said they do run a little hot. Temps below 250-240 are hard to get if you want to keep the performance.
RE: picco temps
ORIGINAL: joelgould111
Again, there is a 40 page thread on the Picco, ask your question there if you need help. Also, if you demand a quick reply....you won't get it from most people such as me.
