motor question
IL
RE: motor question
The TM has alot more torque and a little more HP , my son can pull wheelies from a dead stop and rolling at 5-10 mph with his REVO .18TM .
I like the 3.3 , but I like the O.S. .18TM alot better !
RE: motor question
ORIGINAL: KRO
RE: motor question
ORIGINAL: gofastkid
I have a tmaxx and I was wondering if I should keep my 3.3 motor or get a os 18mt. what should I do?
GA
RE: motor question
Is there some reason you're asking that question?
If the 3.3 is doing fine for then why would you change?
If the 3.3 has issues then you need to determine if they are the fault of the engine or the operator. (no offense intended but sometimes newbs have engine issues that they think a new motor will fix when what they really need is more experence)
If you just want more power then the TM is not your best choice.
RE: motor question
ORIGINAL: DaveG55
+1
You need to look into a Picco or any .21+ big block if you are craving for some power.
RE: motor question
Below is a collection of information for the COMMON small & mid block engines installed in a REVO. I have avoided HP, Torque, & Price intentionally. I thought this might be useful to someone thinking about replacing their engine. This list deals with what is commonly called “Drop-in” engines. If I have missed any or have any wrong info please let me know. Opinions & comments are always accepted (like I have a choice…lol)
EZ = EZstart
RT= Rotostart or Jumpstart
PS= Pullstart
SB=starter box (bump start)
RT adapter: Conversion that replaces the EZ or PS on a PS engine
SB adapter: Conversion that replaces the EZ or PS w/o grinding down crank nub
Non PS version: Used for new install with SB
Note: You can usually bump start an engine with a RT or PS in place but you’re still carrying the weight of it.
Small Block
Model: TRX 2.5R (.15)
Mount: none required
Starting System: EZ or PS compatible
Additional Parts: includes PS
RT adapter: Ofna TRX Engine Backplate (OFN50007)
SB adapter: Maximizer TRX 2.5R, 3.3R Backplate (w/ heatsink) (MAX2245)
Non PS version: Available
Model: OS .18 TM w/Revo Manifold
Mount: None needed
Additional Parts:comes with exhaust manifold
Non PS version: none
Model: TRX 3.3 (.20)
Additional Parts: includes pullstart
Non PS version: TRA5404
Mid-Block
Model: RB Concept TM323 .23 Revo
Mount: provided
Additional Parts: comes with rear pipe & manifold
SB adapter: Non Pull Start Rear Engine Back Plate (RBC01901-323210)
Model: RB Concept TM523 .23 Revo
Mount: provided
Model: Picco .26 MAX
Mount: requires OFNA engine mount
Additional Parts: comes with pull start
RT adapter: Ofna Picco .26 Max Engine Backplate (Roto-Start)(OFN50010)
SB adapter: unknown
Model: Sirio .27 (S27RE)
Mount: provided
Additional Parts: comes with mount & manifold
RT adapter: unknown
SB adapter: unknown
EZ = EZstart
PS= Pullstart
Small Block
Mount: None needed
Mid-Block
Mount: provided
Mount: provided
SB adapter: unknown
Mount: provided
RT adapter: unknown
SB adapter: unknown
