can i put my revo 2.5 on a 3.3 chassis?
FL
i have a 2.5 revo and was wandering if i can buy a 3.3 revo chassis, would everything off a 2.5 fit on the 3.3 chassis?? i know i would have to buy longer center drive shafts. thanks guys
My Feedback: (50)
RE: can i put my revo 2.5 on a 3.3 chassis?
The front steering tie rods are longer as well. Just buy a set off the bay or you can probably get them from your LHS. I have an after market extended chassis that came with the drive shaft and that was all I needed since they extended it between the tranny and the steering and traxxas extended it after the the steering.
Here is what you need to make your 2.5 into a 3.3
http://impaktrc.com/product_info.php...roducts_id=490
You don't have to get the tranny halves unless you are going to get the center diff and rear brakes though. This kit even comes with a new body, its a pretty good deal for what you get.
FL
i want to thank all of you for the info. its gladly appreciated and im glad i just did order the 3.3 chassis and get all the other lil suprises. thanks again
