Added 1100 mah 6c battery and nothing works?
NM
So i got tired of buying and replacing batteries so i bought a new 6v battery and charger off ebay. Battery was new but not a traxxas battery and a Revo battery charger. I charged it and when i plug it in, sometimes the servor twich then nothing or some time nothing at all. I put my old battery pack back in and it works. I thought i had a bad charger so my brother charged his it up and same thing happens. Do these receiver not work with battery packs?
GA
RE: Added 1100 mah 6c battery and nothing works?
I run hump packs on all my trucks (including a T-Maxx and a Revo) and they work fine.
Heck, the Revo COMES with a rechargable rx pack.
If you've tried two different charges then the obvious implication would be that you've gotten a bad battery pack.
I'd test it by measuring the battery voltage while the battery is under a load, that will tell you what''s up.
NM
SO after playing with it for awhile, i found that it works finw when i disonecct the steering servo. Once i connect that servo it stops working. The servo is a Blue Bird MG620 (something i found off ebay).
NM
But the servo work dine with a battery pack with 4 AA's , shouldnt it work with the other too? Im confused on why it works with one battery source and not the other.
Dead battery. That steering servo is by far the biggest drain on the battery pack, compared to it everything else is small fry. Your battery works on the smaller items but it chokes when you attach it to the high amp draw steering servo.
GA
Bluebird servos don't have that great a reputation but, as long as it works with the alkaline's, then that should not be the problem. I still think you've got a bad battery pack. As i said above, measure the battery voltage while it's under a load. That will be the easiest, surest way to test it.
