body questions
body questions
sorry about wrong section no one in the right section replys lol good old traxxas lot are allways here to hellp lol ok i bought a nitro rs4 3 for 20 dollers it is almost new al it needs is a new axle and body and some wheeles and it s ready to go i lost the wheeles lol i left them at the park i came back and they were gone ok any way if i buy a 190mm body will it fith the car takes 200mm its only 1 cm but i dont know help please
PA
RE: body questions
the measurements like that (190 and 200mm) are the width of the car. if it is a 200mm car run the correct sized body if you dont wheels will rub on the body which can cut your tires, and your turning radius will be increase a ton. also dont run a 200mm on a 190mm car it is too big for the car and will cause other problems
RE: body questions
ok thanks what if i cut the body thow because it will save me about 30 pounds 60 dollers to buy a 190mm bacause there is a kit that has 8 rims 16 tyres and 5 bodys
PA
RE: body questions
30 pounds? you must be talking aabout currency. is ther any way for you to get the bodies in the 200mm size rather than 190mm it would take far too much cutting for it to fit even still it wouldnt fit properly and it would be unrecognizable....
RE: body questions
yes curency lol sorry well i can get 200mm but they come with only 4 wheeles and 8 tyres and cost more but the 190mm coume with 8wheeles and 16 tyres so mm i think i will ask if they can sort out the package were i get 200mm body and the lots of wheles and tyres lol
PA
RE: body questions
thats it thats exactly what you need to do. and if you cant do the mix and match deal just spend the extra for the 200mm set. also the 190mm may have a smaller 24mm diameter wheel set whereas most 200mm cars run 26mm wheels so the 190mm set probably wouldnt be worth it to get all the stuff and find out that you cant use most or any of it. the body and wheel size being larger may add to the price which may explain why the 200mm set costs more.
hope i have helped and if not post more questions i may have answers
PA
RE: body questions
i think that maxx and revo bodies should fit the mayhem st due to its smaller size as a truggy. if not maybe a savage specific body (not the ones that fit a maxx and savage they are a little smaller)
