fuel doesnt prime
NJ
fuel doesnt prime
i have beed trying to get my 3.3 to start for some time now, and the fuel does not prime! it will prime when i disconnect the fuel line from the carb thought, but when i put the tubing back on... it does not prime! i cleaned the carb w/ some brake cleaner and let that dry. i put it back and it still dont work!?!? i think there is an air leak in the engine somewhere
what is wrong???!!
what is wrong???!!
RE: fuel doesnt prime
ORIGINAL: sunco1
what is wrong???!!
what is wrong???!!
PA
check your pipe connection, fuel line, the pressure line from the pipe to the tank, and any exaust obstructions that could be stopping the airflow
PA
ORIGINAL: 6speednissan
Have you tried getting it to start when you manually prime it to the carb? Use the method of blowing into your pipe fuel line.
NJ
well i did the but i still have the same problem. and it still doesnt prime when the put the fuel line into the carb. where could this leak be coming from? could it be the header? or the flywheels not being all they way on? its driving me crazy!!! lol
