Robinson Racing RRP T-maxx 2.5 steel 1st and 2nd gear
For all those still running T-maxx 2.5's like me, here is a pic of the new gears from RRP. They're alot heavier than I expected. I would only recommend these if you really needed them or wanted extra durability.
Shawnsr5454 (04-14-2024)
RE: Robinson Racing RRP T-maxx 2.5 steel 1st and 2nd gear
Not sure if you knew, but my tires are jumbo-maxx swamp dawgs, not jombo kongs. Those jumbo kongs are crazy big. The jumbo-maxx tires are inbetween a regular size t-maxx tire and the kong tire.
Are they? I knew it was one of the 2. I thought jumbo kong came out with swamp dawg versions didn't they?
They do have the swamp kong, they're huge. Something like 8.5 inches tall and 4.8 inches wide. I heard they float too.
Here's the rest of the pieces. RRP top shaft, RRP primary and reverse, and GH output gear. Not sure how the aluminum will hold, but it's got to be stronger than the cheap plastic. I also spent the extra dough for some boca ceramics.
Considering this thread is 17 years old, you likely won’t get a response. If these parts are still available, a google search should help. If parts are NLA, then eBay is your friend, unfortunately.
