upgraded from TRX2.5 to Ofna Force .26
I recently upgraded my TRX 2.5 to the big block Ofna .26. The only problem I'm having is figuring out the clutchbell and spur gear compatability, in other words, what clutchbell and spur gear will work together on a standard 2.5 transmission. Any ideas?
RE: upgraded from TRX2.5 to Ofna Force .26
sorry for the confusion mgt uses a 42 pitch (1/8 big blocks). stock maxx uses 32. my bad.
EDIT: or maybe it was 48 pitch. sorry for the confusion. cant ever remember.
Use the MGT spur and then u can use any 1/8 scale clutch setup u want.Or get a Strobe slipper .I wouldnt use the stock clutch setup from the 2.5 on a big block
http://www.rc-monster.com/proddetail...per-Kit&cat=45 .This is a Strobe slipper.It looks like he's out of stock too.Wouldnt hurt to email him,maybe he has one.They turn up on EBAY every once in awhile too.I believe the elusive Strobe sprong is on EBAY right now.That eliminates the need for the stupid little tension spring when using a Strobe Slipper
