e-maxx tranny in t-maxx
just curious as how hard it would be to do so. kinda want the manual shift option. think the only diffucult part would be getting the spur and clutch bell to line up. it looks very similar to the t-maxx tranny except the spur being in the center and the shifter is on the opposite side(and of course the gears inside are a little differant).
RE: e-maxx tranny in t-maxx
I did this in my old .15 t-maxx. Worked fine but trying to sort a brake out made me end up putting the T tranny back in
cool deal, so did you use the stock clutch bell and spur? anything else you had to mod? wasnt really to worried about reverse. i have my old t-maxx .15 i was planning on using so that will work. i have it set up 2wd and was thinkin about doing a front brake. dont guess you could do the manual shift option to a t-maxx tranny seeing that the gears are set up differant(not to mention the ratios).
