gorrilllaaa t- max
gorrilllaaa t- max
need help with gorrillaaa t- max installed a new cen 7.7 motor and are having trans. spur trouble running a rc solutions 54 tooth metric hardened spur gear and is pointing the top of spur gear anybody have a other solution to problem and other spur gear? input needed thanks dan
AB, CANADA
RE: gorrilllaaa t- max
Do you mean the teeth on the spur gear are wearing to a sharp point at the tip? If so, you either have mis-matched gear pitches on the pinion and spur, or you are running without enough clearance between the gears.
I am guessing it's a pitch problem. I don't know what the Tmaxx pitch is, but the Revo uses a metric pitch of Module 1.0. Only another gear with a pitch of Module 1.0 will mesh correctly, even if some other pitches are close. As the trucks share many driveline parts, it's very possible the the Tmaxx uses a 1.0 pitch..... but I'm too lazy to check myself.
