2.5r to 3.3/won't start/break in
I switched out the 2.5r in my revo to the 3.3. Today, is break in day. The 3.3 however will not turn over. I sounds like it wants to, but it never fully gets to the point where it will stay running. I put the LSN and HSN back to factory settings, but didn't touch the idle. Any ideas would be great since I would like to get it broke in today.
Jacob
Jacob
ON, CANADA
RE: 2.5r to 3.3/won't start/break in
change the glowplug.....use a regular glow ignitor...loosen the glowplug a bit until it fires then tighten it.....
Did you check your glow plug to make sure it's good.Is it motor flooded.Are you using a igniter.You might have to heat the head with a blow dryer first then try to start it.If you try that,take the plug out heat the head then ad some ARO the crank it for about ten seconds then repeat one more time then try to start it.Also you might have to richen it a little to get more fuel to get it running.hope this helps.
