Tmax Brakes
Tmax Brakes
My truck brakes are not very strong so I want to replace them. I was wondering what is the easiest way to do this? I dont know what has too come off. I dont want to take more apart then I have too. Also what are good brakes aftermarket are just stick with Traxxas?
WI
RE: Tmax Brakes
If it had good brakes, but now it doesn't, and nothing has changed, (other than massive brake usage)...........
Check the mounting screws for the brake assembly....tighten them up and you should have better brakes. I did.
RE: Tmax Brakes
I ended up using a hpi baja bug steering servo for my brakes and throttle. I can now flip it over if I want to and that's on standard disk and pads and it's stopping a 25cc strimmer engine!!
RE: Tmax Brakes
make sure you shim your diffs,, if your runing real hard brakes... just learnt a lesson today,, was running hardcore on the tarmac nad my brakes were soo hard, and since my tires were gripping hard on the tar,, the diffs kinda packed up,,!!
