survo help...
CA
so i have a new emaxx with dual steering survos. i was driving around and i hit a fire hydrant and broke the gears in the survos. i replaced all the gears that broke. now its not working. it still steers but its sounds like its slipping but i dont no what to do. any help at all would be good.
thanks
thanks
CA
take it to a hobby shop and let the pros fix it. i would reccomend taking it to the one that you bought it at. they most likely will repair for free, you just buy the parts
ORIGINAL: smoken u!
Check to see if you stripped the threads on the servo horns.(they connect to the servo nd turnbuckles. should be one screw to take them out.)
