t maxx steering servo?!
CA
i have a t maxx with a OS .18 rear exhaust engine and my steering only turns fully one way and doesnt turn fully all the way the other...
so im guessing its the servo or the ummm i cant think of the name but im gonna say steering bellcranks...
so i want to know a good high-tech/high-torque servo i can buy...
thanks guys im an just getting into these and dont know what to really look for...
thanks
thanks
CA
RE: t maxx steering servo?!
ORIGINAL: maxxin2.5
thanks
thanks
CA
ummm just a good bashing servo would be fine...
and idk i want to spend to much money on it...
so could you send a link to those two servos??
CA
ORIGINAL: maxxin2.5
Hitec HS-625MG High-Speed 2BB Metal Gear Servo $35.99.
Motor Type: 3 Pole
Bearing Type: Dual Ball Bearing
Speed: 0.18 / 0.15 sec @ 60 deg.
Torque: 76.37 / 94.43 oz.in (6 volts)
http://www3.towerhobbies.com/cgi-bin...5MG+&search=Go
Hitec HS-635HB High-Torque Karbonite Gear Servo $29.99
Motor Type: 3 Pole
Torque: 69.43 / 83.32 oz.in (6 volts)
http://www3.towerhobbies.com/cgi-bin...+635&search=Go
HI
I think this is better than the two above and not that much more http://www.impaktrc.com/product_info...roducts_id=317
CA
ORIGINAL: jessemxt
VA
i am glad someone started this post cause i have the same problem on my maxx
will any of those 3 stand up to hard/severe bashing!!!
now i just need shock rods, half shafts, and new a-arms and i will be ready to roll--------again
CA
ORIGINAL: xtremes15
http://www3.towerhobbies.com/cgi-bin...97TG&search=Go
HSC-5997TG
Digital Titanium High Torque Car Servo
Motor Type: Coreless
Speed: 0.17 / 0.14 sec @ 60deg.
Torque: 136 /181 oz.in (4.8v/6v)
Size: 1.57" x 0.78" x 1.45" 40.00 x 20.00 x 37.00mm
Weight: 2.18oz 62.00g
CA
yeah i mean i dont want to spend too much money and i do not bash to hard...and i dont really need a metal gear servo unless its cheap...
i was looking at this one beacuse one of my buddies told me they heard it was a good one
could you tell me if it is good...
http://cgi.ebay.com/XTM-Cirrus-CDS75...QQcmdZViewItem
CA
ORIGINAL: maxxin2.5
ORIGINAL: maxxin2.5
thanks
thanks
FL
wow.. I found 140oz to be inadequate for my 9 pound truggy,
Id recommend getting something with at least 140oz.. at least 140oz at .15 or .17
Hi-tec has one 925mg I think it is, 170oz .10sec
80oz is to weak for steering IMO 80oz is meant for throttle
CA
ORIGINAL: slayerphonics
CA
ORIGINAL: maxxin2.5
ok now you guys are just confusing me...
CA
ORIGINAL: maxxin2.5
ohhh riiight [sm=71_71.gif]
ok ill just choose
ok ill just choose
