View Poll Results: A poll
Yes but I am planing to remove it
0
0%
I don't know
0
0%
Voters: 43. You may not vote on this poll
Do you have a failsafe installed in your truck?
Hi there!
How many of you have a failsafe installed in the truck, indenpendently on whether you have it as an individual module or integrated in another device (optidrive, receiver, etc.)
AZ
RE: Do you have a failsafe installed in your truck?
i had one in my truck when it worked, saved me tons of money. when i didn't it took off and it a fire hydrant, and took out the right front a arms, and bent 2 of my shocks on my tmaxx plus their super cheap, and that was another reason i got one
AZ
The Revo has a throttle return spring, which brings the servo back to -0- when radio communication is lost. That has generally saved my behind, however it's not "perfect"... unfortunately, I HAD one in the Revo but realized that the LST2 needed it more... so, I moved it.
The one I have is not a actual separate failsafe per say; but the failsafe itself is built-in to the radio system I use which is the spektrum dx 3.0 it has its own built in failsafe and seems to work pretty well; however just as a backup Ive got a good ole throttle return spring just in case I lose all battery power suddenly...
ORIGINAL: matts6887
WY
I have a spekky on my revo and a throttle return spring. And a ofna micro failsafe and throttel return spring on my savage and ofna's on my other two trucks.
AB, CANADA
ORIGINAL: matts6887
ORIGINAL: savtraxx
a lil girl nearly got 2 of her legs broken cause of me GET A FAILSAFE!
Lol, i love grammar.
Spectrum's failsafe only works one way, if you lose volatage then you are screwed.. My 3PM FASST is great, but I should really get a throttle return spring (I'm using rubber bands now...)
ORIGINAL: Mspeed
I am scared to ask, but what is the throttle return trick?
When the throttle is wide open, the servo is pushing the throttle arm. In this case the "throttle return spring" is extended and is trying to pull the throttle arm back.
If the servo batteries run low (or if you loose the connection to your truck and you don't have a failsafe module), the throttle return spring will automatically pull the throttle arm back (the engine goes to idle) because the throttle servo hasn't the power to maintain the spring extended.
The throttle return spring can be considered as a mechanical failsafe whereas the failsafe modules you are hearing about solve the problem by means of electronics.
