Whats the Difference?
Hey guys whats the main difference between these two servos? Which one should I get for my Tmaxx?
http://www.rcplanet.com/Hitec_HS_645.../hrc32645s.htm
http://www.rcplanet.com/Hitec_HS_645.../hrc35645s.htm
KY
RE: Whats the Difference?
ORIGINAL: shakewell519
What will it be used for ?
NC
the item description is wrong on the $49 one its a 5645. its a digital servo were as the standard 645 is analog. both can be used as truck steering servos, used in boats, or anywhere but say retacts on a plane.
KY
If you are wanting a good servo that isn't gonna kill your wallet you may wanna check into the --> Hitec HS-985Mg Coreless Ultra Torque Hd Mg Servo link below. It may be a little more than you want to spend but it is worth it.
Specs
Torque: 172 oz/in @ 6.0 volts
Speed: 0.13 sec/60 degrees @ 6.0volts
Size: 1.6"x0.8"x1.5" (40x20x37mm)
Weight: 2.18 oz. (62 g)
Link --> [link=http://www.rcplanet.com/Hitec_HS_985MG_High_Torque_Servo_p/hrc32985s.htm]Hitec HS-985Mg Coreless Ultra Torque Hd Mg Servo[/link]
Specs
