can i use a 75.570 mhz crystal on my tq3 27 mhz controller and reciever??
CA
we just realized me and my buddy have the exact same frequency on our emaxx.
the only spare crystals we have our some 75 mhz for the reciever and the controller...will this work. i dont want to try it because im scared it might short somehting out in the traxxas controller and reciever and clues?
thanks
thanks
RE: can i use a 75.570 mhz crystal on my tq3 27 mhz controller and reciever??
you wont short anything out by doing that, however im sorry but crystals on the 75 band will not work with 27meg radios, you'll need to get some 27meg cyrstals. i have a bunch of 27 meg cyrstals (i've gone 75meg fm) which one do you guys already have? should be color coded.
CA
we both have the yellow one....27.145. it was gettin late so we pretty much jus took turns playing. we rescheduled for next week. thanks for your help!
ORIGINAL: Nighthawk z450
yep,, they made them in both 27 and 75 meg.
when?
all i've ever seen is 27mhz
blue,
you can try installing the 75 mhz x-tals in the radio
you won't hurt anything
weather they work or not, idk
i would think not but ????????
in any case
your lhs will have crystals
shouldn't be more that $10 - $12 or so for the set
ORIGINAL: blueb8llz
[email protected]
isaac
Banned
It will work ,but you may suffer from servo twitch more.
lt will not damage anything to try it with engine off.
AZ
CA
swap the transmit and receiver crystals on one of the radios..should work..
yeah just swap them and try,, then come on here and tell these people how it didnt work... THEN ill get those blue cyrstals in the mail on there way...
again,, as i say alot on here,, "im not speaking from "hear say" but from exsperiance" i have both 27 am and 75am mhz tx's and rx's down in my shop right now,, i have tryed,, it does not work..
CA
thanks again nighthawk! i really do appreciate your help and will be waiting for the blue crystals.
no problem, glad i could help. there all packed and will be shipped 1st thing monday morning on the way to work.
Isaac
Isaac
CA
ORIGINAL: Oasis TR
For one swapping 27 band AM crystals does work !! (transmit and receiver..old school trick from the 80's) It changes it enough that it wont cause interference..I say try it and prove me wrong..I just swaped transmit and receiver crystals in a savage and it worked..
lol wow,, did you even bother reading the rest of the post's before posting?
yes,, you can swap "27mhz" crystals in rx's and tx's that are "27mhz" the ? was if you can use "75mhz" crystals in a "27mhz" radio, in which, the anwser is no..
CA
[quote]ORIGINAL: Nighthawk z450
ORIGINAL: Oasis TR
crystals
Yes I did..We use to swap 27 AM crystals (transmit and receiver) when I had my race track, So the guys could still race..I guess I miss took your reply..But if you read both of our responses you can see how this could happen.
