tmax help..
tmax help..
ok well i got a new motor and i insisted that I put it in...but the ppl at the hobbie store did it. when they did they didn't set something right so when i throttle up the arm that connects to the carborator hits the spur gear...i end up having to to adjust the throttle trim. Is there a way to fix this without doing that. Finally i'd like some tunning tips cause i can never get it right =\\\\
RE: tmax help..
yep,, on the arm that attaches to the carb, there is a small allen pinion bolt (oposed side to where the trottle linkage hooks up) you can simple loosen that and rotate the shaft where you need it.
as far as tuning goes, traxxas.com has some great stuff on it for a beginer
