spur gear
spur gear
so i've got an older t-maxx like the pro .15 but i've converted to a picco .26, foc, 4 1/8 scale shocks, truggy tires and revo shafts my problem is i put lower stall springs on my 3 shoe clutch and now it chips teeth off the stock plastic spur gears. So should i get a metal spur of what? I never had problems with an .18tm.
RE: spur gear
How thick are the springs? They shouldn't hurt the spur gear like that. It might just be that your mesh is off. Are you running a slipper clutch?
RE: spur gear
.09 i think i think i may have gotten a small rock between the gears because it looks like the bell spun on the gear. I'm sure the mesh was right.
