Transmitter off LAST!!!
NJ
Well after an hour of fun this afternoon, we were getting ready to quit.
I turned off the TX so my Fail Safe put the brakes on to let the fuel burn up.
Then like a big dummy, I reached down and turned off the RX..... Oh. !@#$%&%*!!!!
I couldn't kill the engine fast enough and off she went.. WOT for about 100 ft and into a chain link fence..... a post that is.
That just killed my day. I sent my friend to get the pc's.
Damage:
Bulkhead (have grey's in stock)
Both A-Arm's
Tie rod end
2 shock rod ends
steering drag link
Question.. Are the A-Arms for the 2.5 and 3.3 the same? Tower says no. What parts are the same?
Damage:
Both A-Arm's
Tie rod end
2 shock rod ends
steering drag link
PA
RE: Transmitter off LAST!!!
Dude that sucks, I feel your pain. Today I thought the same was going to happen to me.(wot) was breaking in a 3.3 on my maxx and the throttle started cliching real bad. Making me feel like wot was coming any sec. so I stoped and changed the servo. all better. WOT is never good.
I turn off the transmitter last unless it run out of gas. I always stop engine or let it run out, then reciever then transmitter, hate to see that though
NJ
WOT = Wide Open Throttle
Yeah, I was dummy and wasn't thinking and turn the TX and RX off while it was running.
Not too bad though damage was assessed at $30 - I had some parts in stock.
Ouch man, that sux to say the least!! I feel for ya for sure!!! I'm just glad I haven't had the unfortunate luck of having this happen to me yet(thank goodness) [X(]
i once started my truck without extending my antena on the remote. i started to drive outside my driveway gate to warm up the engine and it went out of range. it went 1/3 speed under a car and i was lucky that only my air filter broke. had to take the tyres off the truck to get it back out
CT
ouch. can you still get the parts to fix those shocks? pro-line doesn't make them anymore, so you may have to do some searching. good luck.
NJ
ORIGINAL: NitroBobby
Just the ends are broken... shafts seem fine.. I'll find ends that fit.
AZ
ORIGINAL: ufdfireman
Damage:
Both A-Arm's
Tie rod end
2 shock rod ends
steering drag link
Damage:
Both A-Arm's
Tie rod end
2 shock rod ends
steering drag link
PA
I had a runaway today to w/ a truggy but eh still reltaes. hit my moms car, climbed a rock wall and I jumped infront of it to stop it. It was my ON/OFF switch it groke and sent it WOT....
