Need some carb recommendations
TX
Wanna get a new carb for my TRX 3.3 and wanted to get some opinions from the Temple of Nitro. Any suggestions?
Thanks.
Thanks.
RE: Need some carb recommendations
The O.S. 11k carb will fit perfectly. [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHKW5&P=Z]Kind of expensive though..[/link] Why do you want a new one?
TX
Eeek! that is expensive. [X(]
Well wanted a better carb to go along with the buku on the trx 3.3 is all. I don't necessarily have problems with the stock, just was curious if there was something that worked better.[8D]
Would like to get an Ofna force .26 carb but it's not made anymore.
WY
I don't think the picco carb will fit otherwise people would be replacing them with a 11k carb since the picco carbs have issues with the sleeve coming off. The 11k or the force .26 carb are both nice upgrades and will add a lil more power. I use a 11k carb on my 3.3. Check out ebay you might be able to find a cheap 11k carb or a force carb on there.
