3.3 only 2 months old big problem
CA
I took my revo out today for a little run, the motor has about a gallon and a half through it and the trucks barely 2 months old. i have a temp guage and keep track of my temps my truck has never hit above 265-270 to the best of my knowledge can someone tell me from the photos why the piston rod crack like that? Does it seem like the motor has been run to lean?
CA
RE: 3.3 only 2 months old big problem
If i called traxxas do you think it would fall under manufacturer defects? i mean should a rod crack in half like that? i guess it was a sign when on break in the one way seized onto the crank shaft, maybe the motor wasnt built correctly.
ORIGINAL: MAXXCHEVY
CA
yes that is one thing they do have is great CS, they aready sent me a one way, backplate and shaft. My throttle servo went out and they are sending me a new one.....I figured i would call them and try to explain my situation to me it seems something like this shouldnt happen my last t-maxx motor last me more then 5 years.
CA
What are good cheap websites to pick up a new motor just incase i need to buy one i know there is A-main, tower, 2cool rc, but what are others?
CA
ORIGINAL: MAXXCHEVY
MAXXCHEVY
I can't see properly on your first photo but is thre head on that piston light brown (ok) or blue (too lean)? Or a bit of both?
I have fried a glow engine like that before by running it too lean. It seems like the engine is going well but its screaming like a banshee.
However, you say the temp never went over 270. What was the ambient temp when you were running the motor? Remember that in cold weather you cannot simply lean the motor to get the temp up because then not enough oil lubricant gets into the motor.
hey dudes thats exactly what happened with me last year! i mean me revo was only 4 months old and the con rod broke into 2 halfs in the middle! after that i bought a new piston/sleeve and a con rod! after ive broken in my engine my carburetor broke!! im telling you guys revo 3.3 is perfect but this trx 3.3 is the most crappy engine ive ever seen!!! its just too sensitive! thats why im running with a .28 axial now for 4 months and i have the same high performance!!(because i got tired of wasting my money on trx 3.3 i bought the axial)!!!!!!
TN
I love my 3.3. I will hit the gallon mark anytime now and it just screams. The driveshafts are soooooo twisted on my t-maxx 2.5 that wrds can't even explain it
CA
ORIGINAL: Rawlpower
MAXXCHEVY
MAXXCHEVY
ORIGINAL: MAXXCHEVY
The head of the piston is a light brown color i never run my motors too lean, i always worries i will fry the piston but i guess your never safe
ORIGINAL: Rawlpower
MAXXCHEVY
MAXXCHEVY
You may say that u never run any of ur engines too lean, but how do u know for sure u didn't mistakenly run it too lean; like where u thought the needle(s) were set rich enough but in reality they really weren't?
CA
ORIGINAL: matts6887
ORIGINAL: MAXXCHEVY
ORIGINAL: Rawlpower
MAXXCHEVY
MAXXCHEVY
IN
Maxxchevy,
I just picked up a replacement liner, piston, rod, pin, clip, crank, backplate, starting shaft, case and bearings for $49.99 from Rapidrcparts.com. Ordered them Tuesday, got them thursday. All the parts were assembled also, all I had to do was switch the EZ start, head, flywheel, carb, and exhaust. Basically a new motor for $49.99. I though it was too good to be true.
Martin
Martin
CA
Maxxchevy, this exact thing happend to me, I was running my revo in a lot next to my house, and it started actin up a bit, and then it just died, i tried pulling the pullstart but it seized up., so I took it apart and my rod was broken in half. So what should I go about doing to fix it?
CA
Well i just got off the line with traxxas and they believe it can be handled under warrenty, they want me to send the motor in to check it out but it seems like ill will be well taken care of. Its amazing that they seem to just handle everything will little explaination. I must say that picco .26 max was looking kinda good (maybe the dark side in the future)
NJ
unfortunately, i am in the 3.3 broken rod club. i switched to the resonator pipe and never readjusted my needle settings. absolutely my fault. you would think it would be more forgiving but it isnt. it definitely isnt a novice engine. you would have thought that traxxas would have done something about it by now. do a search, every other day somebody joins the club.
CA
ORIGINAL: benpimpin
Haha Look at me answering questions like Im an expert now 16 replys ago i was the one asking questions, well ben it depends on how old the truck is and how much fuel you have run through it try calling traxxas and see if they will work with you (P.S. When you on the phone its best to say as least as possible)
CA
cool looks like i will be giving them a call, I am not sure how much fuel has been ran through it, i traded my cen gst 7.7 last week for it. Its the 3.3 revo.. If its not under warranty I head something about if you send in your old motor, traxxas will give you a new one for half the price or something like that, is this true?
ORIGINAL: benpimpin
ORIGINAL: big terp 77
with the con rods
but i really don't think it's as bad
as the internet boards make it seem
you really have to look at
the total number of those engines
in circulation
i'd bet they sell 100,000 of them
or more a month
and they've been out for, what
2 years now?
that would mean there are
probably more than 2 million
3.3's out there. that makes the few
that we hear about a pretty
tiny percentage
not saying that makes it
any more pleasant when it's
your's that dies
just that there has to be some perspective
and at least traxxas
is taking care of it's
customers that do have problems
ORIGINAL: MAXXCHEVY
well for starters i didnt turn my hs leaner then 3/8 of a turn from the stock 4 turns the Ls stayed at stock flush the whole time, the truck ran well plus im always worried bout temps ....this isnt the first motor ive tuned.
ORIGINAL: matts6887
ORIGINAL: MAXXCHEVY
ORIGINAL: Rawlpower
MAXXCHEVY
MAXXCHEVY
You have to see how the engine is running, thats the best way to see if you're running lean.
CA
ORIGINAL: JB COMP
On my TRX 2.5R the HSN is 5 turns out and the LSN is factory, and its not running real rich, Temps don't mean its rich or lean. Needles setting don't mean its rich or lean. If I ran mine at 4 turns out on the HSN I would fry mine.
but temps mean that the motor is running at the appropriate opperating temp, otherwise to high and you will def blow up ur motor.
btw arent well all on the same side as hobbiers? i know people like to give their 2 cents but im fine with just getting 1 penny thanks
