OFFICIAL REVO PLATINUM THREAD
RE: OFFICIAL REVO PLATINUM THREAD
i think they have 500k weight that works good but realistically you should just take out the diff if you want to pop wheelies
WY
Wow....we dont need a thread for this.
The platinum has pretty much every hop up needed. If you want to pop wheelies then take out the center diff and rear brake and put an FOC in. Cant imagine why you would want to buy a race truck and use it too pop wheelies...
here are a few pics of my platinum,it started as a rolling chassis I put a picco red dot .26 with motor saver filter , intigy 34t spur rrp 19t clutch bell and rrp wide 43/38t trannie i also have a 17t clutch bell and 36t and 38t spurs and a vantage pipe and a trinity pipe ,100000 oil in rear diff and 6.5 lb springs on back ,I plan on getting mip cvds all around , my servos are s9351 Digital High Torque Coreless for throttle and i have 2 S9452 Digital Hi-Speed.Hi-Torque Coreless Servo's for steering with a futaba 603fs fasst recever with a 3pk transmitter .
OH
nice lookin ride you got there dkastil... how do you like the Picco .26?? thats the engine im looking to get, but not sure if it would drop in my maxx....
Like TMD said, nice truck ya got there man; and I too am considering getting this one once the 3.3 in my revo goes bye bye....[8D]
WY
Sorry, been a little busy.
Here's my setup
Front Suspension-
4 Caster Clips in front
Orange springs w/#1 pistons and 50wt shock oil
Rockers-P2
Roll center-upper
Pushrod location-middle
Bump steer- mid low
Camber- 0
Toe angle- 0
Rear Suspension
Gold springs w/ #2 pistons and 50wt shock oil
Rockers-P2
Roll center- low
Pushrod location- middle
Reactive Toe angle- mid
Toe angle- 1.5
Camber- 0
Traxxas adjustable rear a-arms-19mm
Differentials
Front Differential wt oil- 50wt
Rear Differential wt oil-30k
Engine/Exhaust
3.3 w/11k carb and slight mod job or 18tm
Glow plug- O.S. R5
Pipe- Stock with boared out stinger
Header- Trinity Big Block
Starter- Bump Box
Fuel- Byrons Gen II 20%
Transmission/Clutch
Spur Gear- 38T
Clutch Bell- 16T
Clutch shoes- Stock
Flywheel- Traxxas 40mm vented
2nd gear set- 38T Wide
FOC
Slipper-Firm (locked)
Oomps SS Conversion.
Tires/Wheels/Hexes
Tires-Pro-line Bowtie MTR's
Wheels- Pro-line MT Velocity 1/2 offset
Hexes- Maximizer 17mm composite
Body- Pro-line Desert Rat
Fuel tank- Ofna 9.5 Violater 150cc
Chassis layout- Tekno RX Box Conversion,Tekno Throttle servo mount
Here's my setup
Front Suspension-
Rockers-P2
Roll center-upper
Bump steer- mid low
Camber- 0
Toe angle- 0
Rear Suspension
Rockers-P2
Roll center- low
Toe angle- 1.5
Camber- 0
Differentials
Engine/Exhaust
Glow plug- O.S. R5
Starter- Bump Box
Transmission/Clutch
Spur Gear- 38T
Clutch Bell- 16T
Clutch shoes- Stock
FOC
Tires/Wheels/Hexes
UT
sweet truck dkastil where did you get the controller and how much
Clymer122693 thanks for the setups what is the track like you run on
I just finished painting the body and am still fealing the effects of the paint @^%%^%$#% .Andy the TX is a futaba 3pk with a fasst module and UPgrade graffics decals ,I got it on ebay for 150 and the module and recever for 160 and if you run a fasst system you have to get high end servos that will cost you ,but is is so worth it .
here is a better pic so you can se what tx it is
UT
i have the jr z9100s servo for throttle and jr ds8711 for steering. I know the steering servo has 403 oz of torque at six volts. it is about 130.00 dollars i would imagine the throttle one is to. i just bought this revo platinum about two weeks ago it came with them two servos, the rd logics starter box, upgraded sevo saver, aluminum rear skid plate, rd logics steering nuckles (4) it did not have a contoller so i used a traxxas one i had. i might get a better one fo crhistmas. i bought this for 400 dollars
UT
forgot to metion i had to get a new engine becouse a bearing went bad a messed it up. i was going to post pics but i cant find my camera
OK
I saw this and was wondering if anyone can tell me how the 603fs is wired in an ERevo? I'm changing over to the FASSt system, but not sure how to plug it in.
T-Daddy
T-Daddy
