Dumb ? center diff
Dumb ? center diff
Ok I am converting my Revo.. I am installing the center diff and rear brake kit, my ? is what do I do with the optidrive unit leave it connected or just connect everything to the reciever
Ron
Ron
RE: Dumb ? center diff
yeah I eliminated reverse, I installed the center diff,rear brake kit and close ratio gear set...
just wondered if I still needed the opti drive to tell if the battery and things worked
Ron
Ron
IL
No reverse = no need for the OptiDrive , yank it out !
If you are racing you might want too look into the Tekno RX box and tank/servo mount , it allows you too ditch the OptiDrive box and the huge throttle servo/shift servo box on the other side .
Cuts a few ounces of weight off and allows you too move the tank forward for better weight bias .
