Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
revo with os.18tz??
Old 09-07-2008, 05:48 PM
rccrawlerkid
Default revo with os.18tz??
i was woundering if i get the os .18tz will i also need a bump box and will i need a bb kit for it???
http://www3.towerhobbies.com/cgi-bin...&I=LXHLV6&P=ML
Old 09-07-2008, 07:50 PM
REVO_RACER
REVO_RACER's Avatar
Default RE: revo with os.18tz??
Im sure you could put a os .18TM Backplate housing on it and run a EZ Start on it (or Pull-Start)
Old 09-07-2008, 09:17 PM
dirtpile
dirtpile's Avatar
The pilot shaft is different than traxxas too. The Traxxas IPS shaft is shorter and has a larger diameter. I suppose it could work with a touring car clutch bell if you could get the spacing right. You'd probably end up getting getting the clutch and flywheel too.
Or you could fit it with the 18tm backplate: [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHKV9&P=V[/link]
And shaft: [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHKV9&P=V[/link]
Which adds $68 to the price and puts it at $218. And you can get a Picco .26Max for less than that.
If you want an OS .18 you can find NIB .18TM's on Ebay for as little as $150 plus shipping. That would be the easiest and likely most cost effective option.
Old 09-07-2008, 10:44 PM
NitroVenom
NitroVenom's Avatar
If you want to use a pull start on it, you will need a 18tm crank, backplate, and starter shaft. You don't need a BB mount. Its a direct fit.
