Quick Revo question
NJ
Quick Revo question
I notice the stock revo sits kinda low. What do you have to do to raise it up a bit? Stiff spring or change the rockers out? Also does the new revo 3.3 come a battery pack for the reciever or does use the AA pack thingy
RE: Quick Revo question
Your gonna want stiffer springs regardless of the ride hight. You can move the pushrods to the inner hole and also tighten the shock collars. I wouldn't make the truck sit too high though because then you'll have problems with rolling over.
NC
your arms should be parrellel to the ground(not any higher or handleing will suffer) . Youl need stiffer springs and thicker shock oil b/c stock is was to soft and doesnt have enough dampening. I use tan for the rear spring and gold for the front springs with 50wt oil rear and 60wt front(stock pistons in the shock). It helps alot!
ORIGINAL: Mule5292
