need longer front shaft for extended chassis
NY
I'm converting everything from my 2.5 Revo chassis to a 3.3 chassis and the front driveshaft is too short. Do I just need to get a longer driveshaft like I did when I put everything on my extended TMaxx chassis??
My Feedback: (13)
OR
RE: need longer front shaft for extended chassis
can you just use an outer drive shaft for the center shaft? that's what I did when I extended my maxx... I even used the stock stubby male splined end and just used the long female splined end... it's not like it extends or contracts...
NY
When I did my T-Maxx I just used extra axle shafts I had and had to cut the female end a little and used that for the center.
