4-stroke gasser Maxx
How about a 4-stroke T-Maxx gasser? I have a truck assembled from spare parts and odds-n-ends and am going to power it with a Ryobi 4-stroke weed eater engine.
The engine had dropped a valve and came from e-bay as a parts engine. I have since made new valves for the engine and have it running.
I would like to keep the T-Maxx 2-speed gear box and use rear wheel drive only for now. I have followed the gasser Maxx thread elsewhere on this forum and see alot of good ideas. Most of them are two cycle weed eater engine powered.
I am really set on using the 4-stroke and looking to shorten it as much as possible, so I don't have to lengthen the chassis alot.
With my lightning fast dial up, I can only load one photo at a time before the session times out.
Has anyone else done a 4-stroke Maxx? Any suggestions or comments welcome.
RE: 4-stroke gasser Maxx
Yes, there is a whole other entire thread on just the subject of a "gasser maxx".I know for a fact its been talked about on these forums before....
Take a look at the following which should help ya out some:
[link=http://www.rcuniverse.com/forum/m_2893529/tm.htm]Gasser Maxx Link[/link]
ORIGINAL: T.L.A.R. eng
Thanks Matts6887, there is alot of good ideas there, but I am wanting to do one with a 4-stroke.
OH
Would that engine even FIT on a Maxx? I kinda remember seeing a four-stroke gasser Maxx once before but I think it was an airplane engine. Try searching the UE forums.
ORIGINAL: dirtpile
I did a Google search and only found 4-stroke airplane engine conversions. There are a couple on YouTube, but I haven't seen any 4-stroke weed eater engines converted to a Maxx.
The Ryobi is way too long with the clutch, magneto and pull starter assembled.
I have found this engine runs great on Blue Thunder glow fuel! So now I am going to shorten the crank and downsize the engine as much as possible so I won't have to extend the chassis a ridiculous amount.
Here is the shortened engine block and motor mount to mate with the Maxx.
I wanted to lay the engine down, but then the weight is all to one side or the other. So I will run it straight up and lower it by doing away with the big bulky plastic oil pan.
As it is, this engine with a clutch is shorter than most two-cycle versions I have seen. I am off to make more parts.
yaris, this engine started life as a Troy-bilt TB475SS string trimmer and it is supposed to be 26 cc.
Here is a photo of the shortened crankshaft. I allso made a steel flywheel to match the new taper on the shaft.
Thereis no cooling fan on this engine and I feel one is not needed running on glow fuel. I am counting a little bit on the over engineered factor that most weed eaters have.
Allso the oiling system will be total loss from the glow fuel.
OH
My advice: Find a smaller, lighter engine or at least widen and lengthen the truck as much as possible. I've got the feeling that engines weight will be an issue that'll be just as hard to overcome as getting it connected to the drivetrain.
Another note: Get the engine mounted as low as possible. It looks like in that picture that it's mounted on a piece of bent aluminum that puts it entirely above the shock towers, do your best to eliminate that and get the COG down.
Good luck with it either way. I would be pretty cool to see you get it running.
Here is a brass oil pan made to reduce the overall engine height. I am going to mount the engine as low as possible in the chassis. The rear driveshaft is the limitation on how low it will go.
Originally I wanted to mount the engine on it's side, but that made the weight biased to one side to keep the clutch bell anywhere close to in line with the trans. This engine isn't that heavy and with a longer chassis, it should work out ok. [sm=72_72.gif]
ORIGINAL: dirtpile
