If I change the teeth on my clutch Tmaxx?
Sorry for all the questions. But if I up the teeth on my clutch is that more low end i.e. more torque or more top end. How does it work in relation to the slipper clutch teeth. Like how do they work in relation to each other? Again Newbie. Knowledge is power.
RE: If I change the teeth on my clutch Tmaxx?
Less teeth on the clutchbell or more teeth on the spur gear will give you more low-end torque, more teeth on the clutchbell or less on the spur will give you more top-end speed.
