revo 3.3
MD
revo 3.3
I have a revo 3.3 and I was thinking about changing the trans out and put a one speed conversion kit in it. What do you think about that?[8D][8D][8D]
RE: revo 3.3
That would not make sense to put a 1-speed transmission because I don't believe there are any companies out there that make a single speed at least that I am aware of; and not just that; if u put a 1-speed trans in; it would change the gear ratios and would also make it slower in terms of overall top speed. That simply does not make sense because a majority of people are looking for MORE power and MORE SPEED!! so why would u want to do that is my?[:-]
MA
RE: revo 3.3
There is a mod for single speed. Either on this forum or Traxxas forum. It for racing on tracks with high HP motors that have alot of torque and can pull second gear like it was first. First then becomes useless and not needed. Also you'll pick up acceleration from less mass in the tranny.( with first gear out) I personally love my speed and the sound it makes everytime it shifts.
RE: revo 3.3
Im with kasarn on this one; I too like the way it sounds when it shifts; as far as why u would need it for just backyard bashing, u are just better off overall leaving the 2-speed in because it gives it a bit more power, etc to climb over things as well as better speed....
RE: revo 3.3
ORIGINAL: motormouth27
when I start the truck it jumps in between foward and reverse what could be wrong with it do you have any problems like that.
RE: revo 3.3
How would you do that.
The FOC (forward only conversion) is a top upgrade for sure, it will give you better acceleration and less to worry about
traxxas dual stage air filter
Revo wing mount and wing
Better engine(picco .26 red dot)
better tires/wheels
Better radio (futaba 3pm)
RE: revo 3.3
what upgrades to do on a revo 3.3
RE: revo 3.3
What is a good tire and rim to buy and if you change the radio do you have to chane the reciever.
As to the radio and receiver part of the ?; yes, u do usually have to change the receiver if u change the radio; especially when it comes to the 2.4ghz spektrum systems; as those receivers have NO crystals to change or dials to change....
RE: revo 3.3
ORIGINAL: quadracer111
Opti drive is poop. Get a forward only conversion and get rid of the opti crap
