View Poll Results: A poll
OptiDrive
0
0%
Voters: 16. You may not vote on this poll
Which Fail Safe
Which Fail Safe
Last night my Revo 3.3 decided to run for the hills. I use the NiMh battery back and it must have run down.... The Truck went wide open and full turn to the right. It narrowly missed my neighbors garage door..... Fortunately that same neighbor has not cut their grass so it slowed the truck down just enough before it slammed into a for sale sign in the front yard. Not too much damage but it could have gone horrible wrong.
So I have done a lot of reading about the fail safe units that are offered and every time I think about buying one I come across another thread that says that specific model sucks and not to waste my money. So which is the best fail safe? I don't really need a temp gauge but like the idea of another option to carrying my temp gun.
Thanks for the input.
OH
RE: Which Fail Safe
If you ever decide to up-grade your Transmitter to say a Spektrum system, it has a built in failsafe. Many other aftermarket radio manufacturers have this also.
RE: Which Fail Safe
ORIGINAL: thesouth1
RE: Which Fail Safe
I had the same thing happen to my 2.5 Revo using the standard Traxxas radio. I use a Venom fail safe and it has not happend since. When the batteries get low the truck just idles instead of running all around the place out of control.
GA
RE: Which Fail Safe
I use the least expensive fail-safe I can find at the time I need one.
I do not reccomend that you get a fail-safe/temp guage combo. A seperate temp gun is far, far more versitile.
CA
RE: Which Fail Safe
man i thought i was the only one!
haha well not the only one..
my truck went ballistic because the batts were low.mtook off wide ope hit a curd did a 5 foot high backflip rolls under a truck screwing up the body them hitting a brick wall flipping upside down going wide out wheels look like pancaks.. man i was scared. my heaert was pounding.. haha
but yeah i need a lot of things for my truck..
FOC
failsafe
temp guage
glow starter
servos (old ones are breaking)
and some stuff just for fun.. but yeah idk i wuld like to say
VENOM without temp gauge
FOC
failsafe
temp guage
glow starter
RE: Which Fail Safe
Thanks for the input.... I will def be ordering one.... The truck is too expensive not to spend ~$20 on a fail safe. Breaking just one or two parts will cost that.
RE: Which Fail Safe
My OFNA Micro came in....
I was able to get it all in the RX box pretty easily.... I have not ran with it but it seems to work when I shut the transmitter off.... The throttle servo applies the brakes.
I have notice it sure makes the servo a lot more shaky like there is a lot of interference.
TX
RE: Which Fail Safe
I use that ofna one too. One thing I really like about it is that it will cause my truck to go into failsafe mode off and on for a while as my batteries get weak. It's kinda my reminder to change my batteries. Of course I just use normal AA batteries.
