Tell me what you think
Here is my order that i am about to place at amain.
x1 JConcepts Rulux 1/8th Truck Wheel 1/2" Offset (White) (4)
x2 Pro-Line Badlands MT Monster Truck Tire (2)
x1 Traxxas Oil, differential (50K weight)- for front diff
x1 Traxxas Rear Brake Kit for Revo 3.3
x1 Traxxas 17T Clutch Bell
x1 Traxxas Revo Gear set, 2-speed wide ratio (2nd speed gear 38T, 13T-18T input gears, hardware)
x1 Dynamite Platinum 1/8 053 MidRange Inline Exhaust System (Hard Anodized)
x1 Team Losi 1/10th Rear Exhaust Maniforld Gaskets (2)
x1 Traxxas 36T Spur
x1 Traxxas Oil, differential (30k weight)- for rear diff
x1 Traxxas Oil, differential (500k weight)- for center diff
x1 Pro-Line Premium Blend CA Tire Glue (Medium, 15-20 sec)
How does it sound?
Any other things or ideas?
x1 Traxxas 36T Spur
How does it sound?
TX
RE: Tell me what you think
how bout putting those badlands on HALF- UPS. looks awsome.....i guess you run a BB, i suggest a high end pipe to get the most out of your motor, even with a high end pipe you will have enough tourqe to throw it on its lid...just look at the savages
Its a mid block, picco .26 red dot and i heard that the 053 was best for the powerband. The badlands dont fit on the badlands i thought?
TX
53 is for more low end power. 86 if for a higher peak power( some one confirm this) you can strech badlands on half ups.. im just saying high end is more usefull for the traxxas trucks,,if you hade a heavy savage, the you would want the 53
Thought so. I would use low end more than top end power, i climb hills and hit jumps so i think i will keep the 053, yes the 086 is for high end.
TX
according to the dyno, the trinty has the advantage off the line. then after 15,000 rpm the 53 whoops it. but im guessing your rpm would be over 15k when your hill climbing. i think
ON, CANADA
i bet you on a dyno that a PE header and modded chrome resonator will kill a trinity! what dyno do you get all this wonderfull info from?
the 053 is prolly the best suited pipe for this motor and is the most reccomended. if you had a dyno and a bunch of different pipe/header set's and spare nitro you'd prolly find a pipe or header that may be better but no one has done this yet, that i know of anyway....
why only 2 badland's? if you mount them on Rulux's i can almost guarantee you will have a hard time keeping the bead's glued. i had issues when gluing MT tire's onto standard MT rim's and running with the picco, they NEVER stayed on! now i run MT size beadlock's and never have any issues with bead's coming loose/off....
TX
tire prep is essential to a good bond, i run badlands on rulux wheels and they are fully glued even with 5 gal. through them.......oh, the dyno info on ab mods.
ORIGINAL: madmaxx1
Absolute... where are you hearing 053 is the best? Just wondering. I seem to remember adam recommending the 086 for the red dot/picco maxx a while back.
As far as needing that bottom end, you don't. I couldn't run my slipper 1/8 turn from tight with a mild pipe and stock 2.5 header on the .26 maxx. That motor is know for it's low end balls and will have more then you can use with no matter what pipe you go with.
Alot of guys on the savage forums are saying bottom end does improve with 053 but it's a pretty big sacrifice on the top end over the 086. That is on BB's though.
Lots of people on the forums have the 053 or recommend the 053. I have a center diff so i am losing quite a bit of low end. I dont need top end that much.
ORIGINAL: absolutemayhem
ab mods web site.. they have dyno graphs of the picco. on the red dot the 53 acually help the mid to top end alot
I don't see any comparison to the 086 though... That graph is comparing the 053 to the trinity pipe.
I guess we won't know for sure until someone tries both or we get a comparison from adam.
TX
true, but the graph shows a huge gain from mid to top....i guess its different then you would think. i guess cause the .26 has BB displacement with a sb exhaust
QC, CANADA
I've tried my 053 on my red dot today, and i'am not impressed at all[&o]
The MACS pipe did'nt make alot of improvement too.
So tonight i'll install back the Trynity (side mount withan Ofna DM-1 manifold) and see if i can see better performance.
My old revo with a .18TZ was a screamer with this pipe.
I'am a little disapointed by the performance of my red dot, and i realy think to go back to the OS .18TZ.[]
ORIGINAL: dakamat
I run a novarossi efra-9853 on my red dot and it flys ! How long have you had your red dot I have a tz and a reddot the reddot is faster ,but it took over a gallon to wake up 100% .
ON, CANADA
ORIGINAL: dakamat
now don't go deleting old post's or anything!
lol
