Power in front wheels but non in the back?
Hi guys, having a little problem with my savage. When riding my truck I only get power from the front wheels not the back wheels.
what could it be and how much for the fix you think? I think it is the DIFF ? Is it a easy fix or a hard fix ?
I hope it has nothing to do with my Trans
IL
RE: Power in front wheels but non in the back?
It is definitely a diff problem. Check your dogbones first. Then open up your diff (which only takes five minutes on the Savage X) and make sure everything is okay. Check for missing teeth or loose screws. Your bearing may have also been cooked. If your front wheels are moving then it isn't the transmission so don't worry. It should be an easy fix.
