Snook Man Pictures
Not too much to tell.
This truck is based on the stock 2.5 chassis. I made a custom chassis extension similar to the mono block by UE to fit the BB engine and pipe.
I used my own custom shock towers to be able to take advantage of the 1/8th scale ofna LX One shock length and designed the towers to use either the tekno or revo wing mount. the tower also has access for a roto start wand through the rear.
I also modified the shocks with the revo VD shock pistons.
The tranny is a 2.5 tranny with a revo center diff and my custom rear brake setup.
Ofna violator fuel tank, 3.3 spec axle carriers and axles. UE titanium center dog bone drive shafts and cups and EMaxx diffs.
Here's a few pics at varying stages. I'm building 2 more based on this set up over the winter but using the UE Predator & Thunder chassis's
I have also figured out how to use the HPI savage dog bones for the wheel axle's and plan to use them on the next builds.
I spent a lot of time in Princeton at an archery shop called Primitive Weapons way back when.
