wont shift
RE: wont shift
well could be a few problems......(1)shift point set to high.......(2)most likely though if it was shifting b4 ur outta tune,mine wont shift if its too rich....try leaning her out a lil on ur HSN 1/8 turns at a time then test, dont over do it and keep ur eye open for smoke,no smoke= no engine
RE: wont shift
tuning has been a big problem for me I think its rich but it screams like its gonna explode I bought this used so I dont know if it even shifts to second but I am getting a lot of smoke and rpm just no shift the motor is a picco max 21
RE: wont shift
well if it screaming like that and it sounds like its gonna explode you should lower the shift point in ur tranny.....if ur not sure how to do this go to the traxxas website and u should find the info there.......http://www.traxxas.com/support/kb_se...0shift%20point........hope this helps!........good luck!
RE: wont shift
o and by the way the picco .21 is a good engine and if its screaming and lots of rpms and still lots of smoke shes probably dialed rite in,rich is good as long as ur still making power,rich means ur putting lots of lube to ur engine
