HSN on t maxx 2.5
MS
HSN on t maxx 2.5
The factory setting is 4 turns out. So is it 4 WHOLE (360 degrees) turns or 4 half turns. I just rebuilt the engine, but it wont start at 4 Whole turns out. Starts and RUNS great at 4 half turns out but is running about 280-300 degrees. If i richen it up from the 4 half turns (maybe 5) it boggs down. Any suggestions? Plus its 100 degrees outside here, and high humidity.
My Feedback: (-1)
AE
RE: HSN on t maxx 2.5
"If i richen it up from the 4 half turns (maybe 5) it boggs down"
You mean you richen half a turn at a time?[sm=50_50.gif] Try 1/16th at a time, 1/8th at the most.Since its so hot there, you could try a colder plug, or add a head shim.Both would help control the temps a lil.
