PROBLEMS PROBLEMS PROBLEMS
Well yesterday i broke in my new engine it ran very good well today i was havin some fun and then it stalled i thought it was the fuel cause it was kid of low. then when i restated it it would go for a little amount of time and then just stall even if i changed anything
and i also changesd the glow plugs what could be the problem????[&o][&o] |
RE: PROBLEMS PROBLEMS PROBLEMS
I just started to have the same problem. Would start and bog its way with throttle pulled back, then die when it was let off. I was killing glow plugs
ya the same thing i cant find what is wrong
Does it die when you let off the gas? Or does it start bogging down at full throttle? We need more details of what is happening. Exactly when does it die? Does it idle good? Have you reset the carb to factory settings and retuned? What are the temps of the motor when it dies?
well it doesnt idle good it cuts off and n speed runs it boggs and when i slow down after that it cuts out
running temps (150-170) |
Those temps are way too low. You should be around 200 atleast. It's probably just a little rich. Try leaning out the high speed needs about 1/8 a turn clockwise. Take it for a high speed pass and see if the bogging gets better or goes away. It probably just needs a little tuning. Don't worry so much about the idle until you get the high speed fixed. Get that running really good then you can idle it down or up and adjust the low side for good takeoff. There is a good tuning guide floating around here. I will see if I can find the link.
well what about the stalls and shut downs
It's sounds like it's running really rich and loading up on fuel. You probably notice a lot of oil/gas coming out of the exhaust. Like, if you let it idle and watch the exhaust you probably see a little spray of oil. That's OK, just means it's too rich. Your temps are also a sign it's getting too much fuel. It's not burning enough of the fuel to heat the motor up.
like some others have said it sounds as if the motor is too rich causing it to bog down. Try turning the HSN counterclockwise 1/8th turn at a time until it doesn't bog down. Make sure you still have blue smoke coming from the exhaust though.
like some others have said it sounds as if the motor is too rich causing it to bog down. Try turning the HSN counterclockwise 1/8th turn at a time until it doesn't bog down. Make sure you still have blue smoke coming from the exhaust though |
ORIGINAL: gtbk2 like some others have said it sounds as if the motor is too rich causing it to bog down. Try turning the HSN counterclockwise 1/8th turn at a time until it doesn't bog down. Make sure you still have blue smoke coming from the exhaust though. |
if your talking about the 3.3, how many tanks of fuel have you run thru it? my 3.3 ran ok for the 1st 3 tanks,then started running poor,i called traxxas, they said put a new glow plug in it,run a few tanks at med to high speeds,even if it bogs low to mid range. i did that,kept clearing out the exhaust,and after like 7 tanks, the engine started to run ok.they said it takes a good 15 tanks before it is totally broken in,it loaded up bad down ,but i still kept runnin it med to high speeds. lean the hsn ,then after thats set,start to lean the lsn. very important to install a new TRAXXAS glow plug after about 4 or 5 tanks. good luck
no its a new 2.5r engine i got for my revo 2.5r i killed the other one
Its to rich..Lean it out a bit.
well my pullstarter went so now i am lookin for a spin starter
the spin starter that i like the best is the tiger drive or the yank elminator either one uses a electric drill the yank elminator has the one way bulit in and its just a shaft
I had a simlar issue, I wasn't bogging down but I would stall out when I stopped - I ended up having my cluch spring go out on me, replaced it and all was good
| All times are GMT -8. The time now is 10:47 AM. |
