please help! i want to go muddin'
hi! i finally got my truck running good. i want to take it to a mud pit, but i was wonderin' if i need to seal anything on my truck please help!
RE: please help!
yes, you need to seal alot of things, especially if you're in Sumter heheheheh....just Kidding, I'm in Columbia, wasaaaaaaaaap :)
seriously, put a baloon around each servo with a zip tie and around the receiver and battery (separate balloons ;)) and mud ride until the jet planes come home. ORIGINAL: muddinrc4life hi! i finally got my truck running good. i want to take it to a mud pit, but i was wonderin' if i need to seal anything on my truck please help! |
RE: please help!
you should also pack under the servo horn with some grease it will stop water/mud from getting in your servos
RE: please help! i want to go muddin'
thanks!
would it be the same for like driving in the rain or somthin like that? could you use seran wrap and just sover the electronics (just keep it clear of the enginge and spur gear?)?
use the balloon...you need it sealed up good no matter what.
ORIGINAL: carlbellybutton10 would it be the same for like driving in the rain or somthin like that? could you use seran wrap and just sover the electronics (just keep it clear of the enginge and spur gear?)? |
http://www.societyofrobots.com/actua...of_servo.shtml I'm going to fill them with mineral oil (baby oil) seal it with super glue, then dip them in plasti-dip. this also works on receivers and ESCs. and as for the battery, just put it in a ballon, and ziptie and silicone the end. I'm also going to use slimline safety connectors to help seal the battery - y - receiver connector, and the servo y connectors. but be prepared to replace bearings often.
make some wheel wells. less trouble than trying to "proof" everything.
I'm gonna laugh my a** off when you go mudboggin with your revo/tmaxx and destroy all your electronics, and wonder why they just smoke when you turn them on, then come asking us for help. wheel wells are a good idea if your stuf is already proofed, but not at all a substitute for proofing.
i have done it before no problem. its more like water resistant with the electric cars. nearly impossible to water "proof" an electric anyways. you should know that brushless. it would be fine if hes just muddin. submerging is a differant story but if your submerging an electric in water, water "proofed" or not its more than likely going to mess something up(cant really water "proof" an electric motor without it overheating not to mention "proofing" servos so they still work efficiently without binding and burning the motor and/or batteries up). im assuming you know the differance in water "proof" and water resistant? not to mention with the wheel wells there is alot less to clean up. lets see here 2 hours max to water proof everything and then 2 hours to clean everything up versus 15 min. to make some wheel wells out of something and 2 seconds for clean up time (depending on if you just rip them off or clean and save them for next time). if you do it right you wont have any problems.
id like to see your wheel wells. I dont think it would be enough but it does sound like a cool idea to keep the truck clean.
ORIGINAL: dirt101 id like to see your wheel wells. I dont think it would be enough but it does sound like a cool idea to keep the truck clean. what do you mean by wheel wells i dont understand lol |
i should of took some pictures of them but i threw them away awhile ago. here lately with all the rain i just made a little box surrounding all of the electronics as well as a box for the sterring servo. camera needs a charge or would take a pic of that. just i used the foil tape (a/c|heating duct work tape) and just formed them around the wheels and cut little holes for the suspension components (leave clearance for suspension travel). when i did them i stuck them to the body. it looks pretty good to if you dont bend the tape to much while your forming them.
