Skymaster F18F super hornet
Hello Guys
I just Finish my Skymaster F18f Super hornet and I need some opinion. When I power the model I am seeing that the Elevator has a small play on the tip up & down movement is it normal? I have installed Savox Servos SC-1230SG 36K
I have used 3mm push rod aluminium horns and aluminium ball clevis. Because I am afraid that it could Flatter in the air . And anyone head problem with the Exhaust I am seeing that one of the tail pipes is not aligned straight it has like 10% to the left. do you thing will effect the flight .
Looking forward to hear from you Guys
