Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Sport Twin Pics
Old 07-11-2011, 02:34 PM
Ed_Moorman
Ed_Moorman's Avatar
Default RE: Sport Twin Pics
Here's another of our sport twins. The design was from both myself and Carl "Flaps" Laffert." He does most of the building and I do the flying. All-in-all, we did 25 twins.
This one he called KOLO, for King Of Left Overs. The wing is from a Corsair kit he was goven that turned out to be with wing kit only. We both came up with the twin book pusher-puller. The booms are Monokote covering tubes with 3 coats of epoxy resin. The other option was to roll plywood. The cardboard tubes worked well and we never had any trouble or failures from them. Essentially, the whole plane was made from left over parts, scrap balsa, hardware, tanks, etc.
The Kolo was a good flying plane. The power was 2 Magnum .52 4-strokes. We had the Maggies on 3 different and never had an engine failure until I ran one out of fuel (it doesn't count).
That's Flaps in the picture. He'll be 90 this year.
ID:	1634048   Click image for larger version
ID:	1634049   Click image for larger version
Old 07-11-2011, 03:02 PM
Ed_Moorman
Ed_Moorman's Avatar
Here I am with another crazy design from Ed & Flaps. I called it the A-Frame.
Flaps had a couple of big dowels and I had this old RC combat foam wing. That sounds like the makings of a twin to me. At this point, he and I were turning out a twin about once a month. We went nuts over them for a while. We did learn an awful lot about them.
Flaps made the fuselage and the tail. 1/4" ply engine mounts for the Magnum .28XL 2-strokes. We both had old servos. I forget what the angles on the fuselage were. I kept telling him to go wider on the spacing, but he was getting worried.
I did the wing-cut holes for the rx & battery and taped them in. The servos were zip-tied on.
It doesn't look like much, but it flew pretty well and sure didn't cost much. The dowels weren't very stiff like carbon fiber tubes, but it's what we had. They would flex during taxi and at times in flight. I did all sorts of acro with the darn thing with no trouble.
If I had to do it again, I'd use carbon fiber tubes and build a box for the radio under the wing. I'd probably airfoil it like a Burnelli design. You can see out scale Burnelli CBY-3 in the scale twin thread.
ID:	1634075   Click image for larger version
ID:	1634076   Click image for larger version
ID:	1634077   Click image for larger version
ID:	1634078   Click image for larger version
ID:	1634079   Click image for larger version
Old 07-11-2011, 04:58 PM
JoeMamma
JoeMamma's Avatar
Just caught this thread. A lot of real nice builds going on here !
Do my ARF’s count ? Picked up the twin bug about ten years ago. Got six twins in my hanger...........3 are scale and 3 are sport.
1. Ten year old TwinStar powered with OS .26 4-strokes.
2. Dual Ace (aka Beechcraft Duke ??) powered with OS .52 4-strokes.
3. EFlite Deuces Wild, electric powered.
4. EFlite P-38, electric powered.
5. Hangar 9 UV-18 DeHavilland Twin Otter, electric powered.
6. TopFlite Cessna 310 powered with OS .91 4-strokes.
The ol’ lady, my TwinStar is now showing her age. The peel-and-stick covering is now loaded up with clear tape to keep her together.
The Dual Ace (aka Beechcraft Duke ??) is my favorite flying twin. Seems like I’m always taking her out to the field. A great flyer with very dependable OS engines !
The Cessna 310 sounds the best ! To me, nuthin’ sounds better than a pair of 4-strokers running in sync ! I’ve got a lot of bucks into her so my fear factor is high.
I must be getting’ older as I’m getting spoiled with the electric powered Deuces Wild, P-38 and Twin Otter. No gummy clean-up.......no stinky car.....just charge and fly !
Joe M.
ID:	1634118   Click image for larger version
ID:	1634119   Click image for larger version
ID:	1634120   Click image for larger version
ID:	1634121   Click image for larger version
ID:	1634122   Click image for larger version
Old 07-17-2011, 03:58 AM
Pumatraca
Pumatraca's Avatar
Mr. Ed: could we see some of your flights on videos? Thanks.
Old 07-17-2011, 07:22 AM
Ed_Moorman
Ed_Moorman's Avatar
I'm sorry, but no one has videoed my flights, twins or otherwise.
Old 07-17-2011, 08:06 AM
  #31
Ed_Moorman
Ed_Moorman's Avatar
This is a twin delta I made by widening a Diamond Dust delta kit. I named it the Dusty Deuce. Power is 2 OS .25FX engines with Jett mufflers. The test flights were with the stock mufflers and 9-6 MA props until I got a good feel of the plane. Then I installed the Jetts and 8-6 or 8-7 APC props.
All the servos except throttles are Hitech digitals. The radio is a JR 9303 using the built-in twin program.
We launch it from a PVC launcher on a table with the legs on one side folded. It's a pretty speedy little plane. Very easy to fly, but it can be hard to keep up with at a distance. The colors help. For takeoff, you hold a little up elevator and have someone pull the pin. It glides in on the grass very nicely for landing.
You might notice that the remote needle valve assemblies are not OS. I got tired of the cast-on assemblies breaking, so I cut these off and installed GMS .25 remote needles. There is no difference in how they work.
ID:	1636376   Click image for larger version
ID:	1636377   Click image for larger version
ID:	1636378   Click image for larger version
ID:	1636379   Click image for larger version
ID:	1636380   Click image for larger version
ID:	1636381   Click image for larger version
Old 07-17-2011, 08:32 AM
  #32
Ed_Moorman
Ed_Moorman's Avatar
After Dusty got old, Flaps and I installed floats for a twin delta seaplane we call the Sea Delta.
The floats are some fiberglass ones I picked up. They have a flange where the top and bottom are joined. It causes a lot of water to be splashed upwards. The whole plane gets soaked on takeoff.
I pulled the higher priced OS .25FX with Jett mufflers and a pair of OS .46LA(10-6 props), plain bearing engines I had. They run well, same speed and don't use any more fuel. I think someone told me that the best .25 ever made was the OS .40LA. The floats don't seem to make much difference in how the plane flies. I didn't try a flat spin with the floats.
The picture where I have a big smile is after the test flight. Notice the plans is covered with water.
On the test flight landing, I hit something just under the water with the left float. It caused the plane to bounce to the right. After I taxied in I noticed the V-bottom of the float was dented in. That has been fixed.
ID:	1636413   Click image for larger version
ID:	1636414   Click image for larger version
ID:	1636415   Click image for larger version
ID:	1636416   Click image for larger version
ID:	1636417   Click image for larger version
ID:	1636418   Click image for larger version
ID:	1636419   Click image for larger version
Old 01-08-2012, 07:12 AM
  #33
Thisstrangeengine
Thisstrangeengine's Avatar
Hello All,
Just wanted to add my pics to the thread. Here are some pics of a twin I designed a few years back. This is my second twin and the first is a Cessna UC-78 Bobcat from RCM plans.
The Bobcat is currently awaiting new covering after stripping the old and having made a few repairs. I am also waiting for plans for a 70" twin Piper Commanche. Can't wait to see those!!!
I designed the nacelles as close to the fuse as possible to aid in keeping it in the air in case of an engine out situation and it has paid off more than once! I had a small video camera on the plane during a throttle servo failure and had to fly the thing at full bore until the fuel ran out.
Bobcat about 15 years ago. My first twin
Bobcat under repairs during the summer of 2011
Twin Engine Video.
[youtube]http://www.youtube.com/watch?v=HbdrSq4IKT4[/youtube]
Old 01-08-2012, 06:36 PM
  #34
SIMCO
My Feedback: (33)
SIMCO's Avatar
A couple that have done their duty. O.S.25's
Old 01-08-2012, 06:39 PM
  #35
SIMCO
My Feedback: (33)
SIMCO's Avatar
Tiger 2plus with O.S. 46's. Sorry crappy image. ground loop persona. In the the air,a true tracker.
Old 01-08-2012, 06:41 PM
  #36
SIMCO
My Feedback: (33)
SIMCO's Avatar
Twin Otter SQUINT scale. 46's on this as well.
ID:	1711723   Click image for larger version
Old 01-08-2012, 06:44 PM
  #37
SIMCO
My Feedback: (33)
SIMCO's Avatar
Another SQUINT scale airplane. DH-4 Caribou. Saito 91's for power. Drop rear door. Now flying in a shopping mall in Plano,Texas.
ID:	1711725   Click image for larger version
Old 07-17-2013, 06:33 PM
  #38
Billsky
My Feedback: (37)
Billsky's Avatar
Do you have the CG location of the twin stik? I am just about complete but need how many inches back the CG is located.
Old 07-18-2013, 04:21 PM
  #39
Ed_Moorman
Ed_Moorman's Avatar
I'm an engineer, so I ought to be precise, but I'm not. I use the main spar or a little behind it for the CG.
Most Sticks, even twins, with the power we normally use come out way nose heavy. My Twin Stick came out that way. As I recall, I used a separate servo mounted underneath in the far rear for the tail wheel and moved the battery to a compartment back near the tail. I get the feeling that most Sticks are designed to have the correct CG with an OS LA, not the heavier ball bearing .46-.55.
Old 07-31-2013, 11:48 AM
  #40
jbarnes
AMR Twin Stick with DLE55's. One of my favorites.
ID:	1904981   Click image for larger version
Old 07-31-2013, 11:55 AM
  #41
Twin_Flyer
JB,
That's very cool! Did you bash a AMR kit or do they produce it?
With twin DLE55's, just how big is it!?
Any video??
Bill S.
Old 07-31-2013, 12:03 PM
  #42
jbarnes
Its a standard AMR RC kit. Its made for twin 30's but I live in Colorado at 5K feet so I beefed it up to handle the 55's. I sheeted the wing a few bays more than the plans called for and added wing struts to provide additional support. Its two years old now and has had many enjoyable flights. Considering building another on this Winter with two DLE35RA's and lighten the structure some. All the AMR RC kits are great, I've built several of their models. Jerry.
Old 07-31-2013, 04:47 PM
  #43
Twin_Flyer
I looked at their site and didn't see it (or any twin kit) listed.
maybe they don't make it anymore...
Bill S.
Old 08-01-2013, 06:02 AM
  #44
jbarnes
Bill, they still produce it; http://www.amr-rc.com/index.php?path...enu=&langue=en
Old 08-01-2013, 09:42 AM
  #45
Twin_Flyer
I think I did see that, but some how thought twin cylinders lol
Nice! Plug in wings are the way to go today.
maybe once i get my giant Nosen trainer in the air (same wing span though its a one piece wing!) and some time with a big bird and gas engines, i may give it a shot.
My Nosen Citabria is close to the same WS as well, but that has a three piece wing thankfully.
Thanks!
Bill S.
