using throttle to turn?
Well, if you are talking about only using throttle, I would have to first admit I have never tried that one.
On the surface, it would seem that it might be like a rudder only turn, but I don't think so.
If you reduce the thrust on one engine, the air flow across the wing also decreases, and so does lift on that wing. This would cause it to fall and pull back due to aerodynamic forces as the plane moves through the air. The other wing would rise and pull forward. You are heading into a spin. Did the WWII pilot do this on the P-38's, three of the veterins I have talked to say that yes, they did actually do this in a dog fight. I am not a full scale pilot, so cannot actually comment.
I do mix the rudder into the engines for aerobatic manuvers, such as hammer heads, and flat spins, but to actually attempt a turn using engines only......seems a bit chancy as we are not in the cockpit feeling our way through this......sounds like a gyro would be in order for safety.
Let us know how it works.........not me.
Good Luck,
Twinman
Good Luck,
Twinman
Will work but...
Unless you have counter-rotating props, the effectiveness of turning with adverse thrust only will be different between left & right turns, as engine torque will be in the same direction (generally turning to the left). In other words, it will be easier to turn left by increasing right engine thust than vice versa. Also, it would help matters if you have up-thrust in both engines and/or the thrust line is below the CG (e.g., a low wing plane).
Incidentally, this is why twins with up-thrust generally have one degree more up on the left engine- to counter the natual adverse yaw of props rotating in the same direction and to make more even the flying characteristics when either engine quits.
throttle will be linked with rudder to turn so i'm hoping it should be ok,
as long as she'll fly then i'll be happy, little teething problems like making the right turns as effective as left turns will come later on, as long as i have control over her then i'm happy! lol
