I4C glow driver
I have an i4C glow adapter on a B-25, the unit works from start position to about 42% throttle then shuts off. I have replaced the engines and need to reverse the throttles to get them going the correct direction. Unfortunately I do not have the instructions for the glow driver to reverse it as well so it works with throttle. Any body out there have the original instructions for one of these units? I sure would appreciate the help.
Thank you in advance.
Mike
Mike
