Yellow Bee 4 engine mods
I've got a bunch of motors and broken parts from a neighbor's Harbor Freight Yellow Bees. I'm designing a scale B-24D to use 4 motors from the Yellow Bees.
I'm not sure how to wire the motors. I anticipate having a 2S Lipo and an ESC for brushed motors, so that when I ask for throttle on Ch 3, all 4 motors spin at equal RPMs.
Could someone help me with a wiring diagram for wiring between the ESC and the motors, or correct any obvious mistaken assumptions I've made so far.
From what I can tell, the motors are brushed 180s. Thanks so much. I'm sort of new to electric flight
Thanks for your input.The stock Yellow Bee configuration is a 4.8V battery pack which runs two motors. There is some sort of electronic speed control included, which controls yaw via differential thrust from the two motors. It's hard to tell if the two motors are in series or parallel, because they run through a weird controller. Is there an easy way to tell how many amps the motors draw at full throttle, so that I can calculate the amp load for 4 instead of 2 motors?
Thanks again for your help
